    Sep 2008
    so so, California
    Default Door from residence to garage
    For some reason I thougt the garage separation door had to be fully weather stripped; smoke seal, shoe, sill etc...? I cant find anywhere that supports this in the IRC or CRC.
    Jim Hime's Avatar
    Jim Hime Guest
    Default Re: Door from residence to garage
    IRC R309.1 may help.
    The intent is a 20 minute fire rated door between the attached garage and living area.
    Quote Originally Posted by Jim Hime View Post
    Jim,
    That is not really the intent, if it was, then a 20 minute door would be required and a 20 minute door is simply one of the options, an option which would more than meet the requirements for that door to the 'outside' and to the garage.
    Marc,
    The garage is outside the thermal envelope of the house, the door to the garage needs to be weatherstripped just like the main entry does and all other doors from the house interior to the 'outside', which includes the garage, which is 'outside' the thermal envelope.
    Sep 2008
    so so, California
    Makes sense...thanks.
    Apr 2007
    state of jefferson
    marc,
    the requirement can be found in the california energy code.
    Sep 2008
    so so, California
    marc,
    Sweet...you have a copy of that handy?
    marc,
    Brian,
    The California energy code says it must be smoke sealed too? Please do provide that code reference, that would make an interesting read ...
    Or are you just referring to the door being weatherstripped?
    Apr 2007
    state of jefferson
    Brian,
    jp,
    no mention of smoke sealing the door in the codes that i am aware of! properly sealed doors limiting air infiltration per energy code will seal smoke i suppose.
    marc,
    section 117 of the 2008 builing energy efficiency standards.
    "joints and other openings in the building envelope that are potential sources of air leakage shall be caulked, gasketed,weatherstripped, or otherwise sealed to limit infiltration and exfiltration."
    Jul 2010
    New York
    If the garage is unconditioned (ie not heated or cooled), the wall (and door) between the residence and the garage forms part of the thermal envelope and therefore must be insulated and the door weatherstripped. There is no smoke-tight requirement for the door. If the garage was conditioned you wouldn't need weatherstripping/sealing at all, just the door; in that situation the lack of weatherstipping would be contrary to common sense, but not the code.
    "BUILDING THERMAL ENVELOPE. The basement walls, exterior walls, floor, roof, and any other building element that enclose conditioned space. This boundary also includes the boundary between conditioned space and any exempt or unconditioned space. "
