    Default building cost: attached vs detached
    What's more expensive to build: detached or attached housing, all other things being equal?
    Default Re: building cost: attached vs detached
    Attached.
    Less foundation, fewer walls, fewer windows, roof requires less time to install, wast and water to unit can be less and the list goes on.
    Attached.
    The question is which is more expensive, so I assume your answer is actually "detached".
    I was hoping you would make correlation.
    Attached less expensive.
    Detached more Expensive.
    No counter-intuitive opinions?
