    Rob Radtke's Avatar
    Rob Radtke Guest
    Default Attic Insulation vs. Termite Inspection Accessibility
    I am purchasing a home that was built in 1962 and it had an addition put on in 2005. The original home is 1500 sq ft and the addition added about 700 sqft. The original part of the home currently has no attic insulation. The house is in southern California where temperatures are warm but termite problems are common.
    I'm trying to decide whether to put insulation in attic. Obviously, it's more energy efficient to insulate the attic, but I also hear that it makes it impossible to inspect the attic for termites. I'm anxious to hear educated opinions on this trade-off.
    Thank you for you help!
    Rob
    PS - A termite inspection has just been completed and two separate spots with evidence of drywood termites were found. These are going to be professionally addressed and the house fumigated next week. So, I'm not afraid of covering existing termite problems. I'm more afraid of not being able to promptly find and fix future problems.
    Default Re: Attic Insulation vs. Termite Inspection Accessibility
    Quote Originally Posted by Rob Radtke View Post
    Rob
    Terminates swarm. They will be noticed in the future. Aha is more important is insulation in the attic. Everyone uses heat and air and you will pay a fortune for it in the future with no insulation.
    Rob Radtke's Avatar
    Rob Radtke Guest
    Hi Ted,
    Thank you for the quick reply. Do you have any opinions on whether it's better to use blown in vs. Batt insulation. Thanks again!
    Sincerely,
    Rob
    New York
    I agree with Ted; You will notice them when they swarm (and shed their wings). Also keep your eyes open for shelter tubes.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    He has a drywood termite problem, so there may not be any shelter tubes unless subs move in.
