    Default Dishwasher Drain
    Saw this setup for a dishwasher drain today. The copper pipe is coming in from the right is from the dishwasher.
    Default Re: Dishwasher Drain
    I think you'd call that a 'low loop'. Good variety of materials too. I like the cleanout.
    Jul 2007
    Is that going up hill after the trap?
    Tom Thompson's Avatar
    Tom Thompson Guest
    Very nice indeed where should I start?
    IAPMO states: Installation instruction and local plumbing code will dictate the requirements. Most installation instructions require drain connections to be minimum 20" above the floor level of the dishwasher.
    Yes it is going up rather than down.
    Phil Brody's Avatar
    Phil Brody Guest
    OK it's silly and wrong but with the exception of being able to clean out the black trap I don't see anything functionally wrong. The uphill run is the smartest thing they did !
    MARVIN TOWNSEN's Avatar
    MARVIN TOWNSEN Guest
    Sheeet thats loocs likes how wees plombs tings aroond hear
    Nov 2007
    Quote Originally Posted by Phil Brody View Post
    No its not, that would be against plumbing codes. The whole mess is wrong. No venting, also the fact the dishwasher would be the lowest point in the plumbing system so when the sewer backs up you will get raw sewerage in your dishwasher. thats tasty
    Here is a picture of the drain downstream from the first picture. It has a little hump in it about midway.
    Often, when I see this type of install, it also violates the manufacturer's limitation on the length of the drain line, which is typically 10'.
