Results 1 to 14 of 14
    Jul 2010
    Kansas City Missouri
    Default sump pit in bedroom
    Is there any code that prohibits having a sump pit and pump in a bedroom closet? The pit has a cover but it is not completely sealed.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Tom Thompson's Avatar
    Tom Thompson Guest
    Default Re: sump pit in bedroom
    Sump pits and sewage ejectors are required to be air tight, sealed and vented to the outside. Location isn't so great but not prohibited.
    Quote Originally Posted by Tom Thompson View Post
    Do you have a cite for the requirement to vent a sump (dewatering) system, as opposed to a sewage ejector system?
    Nov 2007
    I know the local codes for Northern Illinois and Chicago do not require a sump (dewatering) pump to be sealed and vented. Only time they are sealed and vented is when Radon is an issue.
    bruce audretsch's Avatar
    bruce audretsch Guest
    Here in Northern California, I have one in my bedroom and another in the adjoining closet. The AHJ had no issues with them.
    My only complaint is the noise issue. I put mine on a timer.
    I'd be very interested to hear of other opinions.
    Did you check the listing, they may have that on as a 1/2 bath
    Tom Thompson Guest
    California Plumbing Code 710.10 venting 710.14.1 Air & water tight
    De- watering pumps located outside of living areas don't require air tight, vented sumps.
    Inside unsealed or vented sumps would stink from decomposing organic material.
    Nov 2007
    Yes venting must be air and water tight. A sump pump that does not receive any waste water, only receives ground water will not have any decomposing organic material.
    Cape Cod, Massachusetts
    Quote Originally Posted by bruce audretsch
    A TIMER?? - Not Good.
    What happens if the sump is full and overflowing, but the timer is off?
    Ken Amelin
    www.midcapehomeinspection.com
    Rod Smith's Avatar
    Rod Smith Guest
    Question Re: sump pit in bedroom
    I have the same concern as Ken....if it is on a timer, what good is it when the power is off?
    Quote Originally Posted by Rod Smith View Post
    If the power is off, what good is it with or without a timer?
    Rod Smith's Avatar
    Rod Smith Guest
    Exactly....!
    Michael Avis's Avatar
    Michael Avis Guest
    umm...no timer. Battery back-up. Set and forget it.
    In my situation, a timer works. The "flow" is just a constant trickle of groundwater, it doesn't increase appreciably during normal rains.
    If we are having a deluge, I disable the timers, and, I have an emergency generator for power outages.
    No worries.
    And I get no odor from the water or the pit. The stuff coming through is "springwater fresh".
