    Apr 2008
    McKinney Texas
    Default Is this particular Federal Pacific panel as notorious as the Federal Pacific “Stablok
    Found this panel at an inspection today. Is this particular Federal Pacific panel as notorious as the Federal Pacific “Stablok” panels? I have checked some online material and most issues point to the FPE “Stablok” panel and breakers. What about this panel I found today? Is it considered to be a hazard as the Stablok? See photos.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Default Re: Is this particular Federal Pacific panel as notorious as the Federal Pacific “Sta
    FPE is FPE.
    I hope you noted the loose, stranded wires that were not gunned down under the screw.
    Apr 2008
    McKinney Texas
    Nolan, yes. I did. Thanks. There were several things going on with this panel, in addition to being FPE.
    Appreciate the input,
    Gene
    I think those are Stab-Lok breakers. It appears to be a split-bus panel with the odd shaped sockets on the buses.
    Besides the stray wire that 60 amp breaker has a little crack where somebody was clumsy with the screwdriver.
    Lou Romano's Avatar
    Lou Romano Guest
    This is a 3-section split bus Stab-Lok panel! Besides the obvious things you and others have stated did you also call out that it is in a closet?
    I had forgotten that those breakers are only rated a 40 degrees centigrade. There is not even a 40 degree chart in the wiring table anymore.
