    Jul 2009
    Spokane, WA
    Default Clearance to foundation vents
    The home I inspected has grading problems. This is new construction,The grade at the back of the house is above the foundation vents. Wouldn't be a huge fix except they poured a cement patio. I'm calling this out for repair on my report but I cant find a code that supports it. Does anyone have something for recommended grade at foundation vents? Much appreciated.
    Default Re: Clearance to foundation vents
    I could never find this in any code book but my local Pest/Dry Rot folks (Oregon Pest Control Association) requires vent wells whenever there is less than 6" from the lower edge. I thought that was based on an FHA/VA requirement but can't remember.
    My standard write-up is that vent wells should be installed anywhere there is less than 6" clearance beneath the lower edge of a foundation vent. It's amongst the most common things I write up. New house, old house.... pretty much all of them.
    Sep 2009
    Rolla, MO
    Bill
    IRC 401.3 deals with the proper slope which does not exist in you photos. Regardless of any code violations allowing water to get into the crawlspace is a potential structural issue (settlement) and mold issue (health) for the home owner.
    Randy Mayo, P.E.
    http://www.rlmengineers.com
    Quote Originally Posted by Bill Anglin View Post
    I wouldn't say that. The foundation is too low. Sloping the grade away from the house does not seem like an easy solution. What if an exterior drainage system were to be installed? Your perception of huge might not be the same as someone else's - especially when they're paying for it.
    MARVIN TOWNSEN's Avatar
    MARVIN TOWNSEN Guest
    Wow looks like the poured a slab on fill, that ought to hold up well.
    Central Virginia
    Couldn't you re-mediate this issue by removing some soil and creating a graded drainage swale lined with stones or gravel?
    Additionally, there is what appears to be exposed sheathing behind the stairs which is likely to create deterioration and water infiltration issues.
    The full loathe honey, but to the hungry, even what is bitter tastes sweet.
    Sep 2008
    so so, California
    Re grade...
    Feb 2010
    Omaha
    Is this a vented crawlspace. Seems like the crawlspace could have been unvented. Waterproffed/insulated to it was semi conditioned.
    Sep 2010
    NY Finger Lakes Area
    Just curious..............is this a modular that was set on a too-small foundation?I've seen that happen several times. If not, what is the motivation for the cantilever flooring system? And just to note......that's a concrete patio, not cement
    ...........Greg
    Why do you have to quote code to support your supposition?
    I would state its obvious shortcomings, water entry, not good practice, below grade and the ramifications.
