Results 1 to 2 of 2
    Brenda Lauriha's Avatar
    Brenda Lauriha Guest
    Default Architectural Shingle Valley
    What is the best option for valleys using architectural shingles? I understand that if a woven valley is used that it voids the warranty (GAF). Is this correct? There is the "no cut" valley which is what I started to use but with these shingles, it is quite thick. I guess I could always go with the standard cut valley. Any suggestions would be apppreciated. Thank you.
    Default Re: Architectural Shingle Valley
