    Michael Civisca's Avatar
    Michael Civisca Guest
    Exclamation AC is not cooling
    Our upstairs AC system (about 25 years old) is in the attic. It cools the second floor (we all also have a 1 year old system down stairs which is working fine). I just noticed the AC condenser fan is blowing cool air outside. I went upstairs and found it very humid. Obviously something is not working. For the first time I saw frost on the suction line where normally I see condensation (there is a 1" section of the suction tube that is not insulated that I used as a visual indicator). I believe I hear a slight hissing sound in the evaporator coil area above the furnace, and when I turned off the second floor thermostat, that noise slowing died away. The blower did not seem to be working at all, even after letting the system stay off for 15 minutes and switching the thermostat back on.
    Before I call service, I was wondering what this may sound like?
    May 2007
    Tyler, TX
    Default Re: AC is not cooling
    could be several things, but first guess is low on freon
    you haven't noticed it making that same sound on a regular basis? does your other unit make the same sound?
    Bruce Thompson, Lic. #9199
    www.TylerHomeInspector.com
    Quote Originally Posted by Michael Civisca View Post
    Since you indicated the indoor blower did not seem to be working, the frost would be a normal item with a broken fan capacitor or fan motor in the indoor unit.
    www.BAKingHomeInspections.com
    May 2007
    Tyler, TX
    oops, I missed the part about the no-blow blower
    Utah
    Turn fan to off.
    Replace blower filter.
    Let ice melt.
    Turn system on.
    At 25 years it has had a good life. The hissing sound could be caused by several things, most likely it was a leak if the sound has stopped. You will notice a marked savings on the energy bill with a new unit. Sounds like it might be time to sleep downstairs untill the replacement is complete.
    Thank you gentlemen, your posts were helpful. I found the system was 31 years old, the exchanger is rusted and mostly likely showing some cracking. Rather than just replace the blower fan, we will go with all new HVAC system. And yes, we are sleeping in the family room for a week.
    Bob Spermo's Avatar
    Bob Spermo Guest
    Michael,
    Make sure you get the new system properly sized.
