Results 1 to 12 of 12
    Jon mackay's Avatar
    Jon mackay Guest
    Default Possible defective shingles
    Has anyone run across this type of shingle before?
    The owner stated that the roof is only 10 years old which I have a hard time believing.
    There is a tan colored aggregate at the top shingle area under the overlaps that I'm at a loss to explain the purpose.
    Any help would be appreciated.
    Default Re: Possible defective shingles
    I've heard of them and seen them in literature before, but never ran across them in real life ... they look as ugly as I imagined they would.
    Take a standard 3-tab shingle but do not cut the notches out, leaving it a single-tab shingle.
    Those look like they have failed.
    How old are they?
    Maybe just old and failed instead of 'defective'?
    Happens to me all the time:
    "Do you happen to remember when you had the roof replaced?"
    "Well, that would have been around ten years ago... It was right before my husband died"?
    "So that would have been around... "
    " '85. He died in October, 1985..."
    New Mexico
    It looks like the tan layer is a second layer under the new shingles. I haven't seen that type before, but they look worn out. I'd bet there is no more warranty left on them, and it's just aging.
    I have not seen shingles like that ether.
    Rather than reporting it's age (10 years yea,like I believe that) report it's condition.
    IE: This roof looks like it is at or near the end of it's useful life.
    A qualified and licensed roofer should be consulted to determine the repairs needed and cost.
    That tan color is the color of the granules on the top half of the shingles, you can even see the sealant strip on the top brown part.
    Also, how is that gutter mounted? Looks to be some type of bracket going up and over the roof, then attached to/through the shingles.
    That roof is 25+ years if it is a day. HAve the owner put it in writing. That should get some eye pops and f u's going.
    I don't think that roof has any felt on it. That really looks like the decking that is showing through.
    The roof is toast and needs replacing. No need to have a roofer to "evaluate" it, just needs to replace it.
    I totally disagree with that. But ...
    I TOTALLY AGREE with that.
    Maine
    This is a simple call; wish they were all that easy. Shingles need replacing-yesterday!
    John Callan
    John,
    You'd think it would be that easy to call out.
    Why try and analyze it for the sellers or the buyer what went wrong? They need to be replaced.
    Jon mackay's Avatar
    Jon mackay Guest
    Thank you for all the comments.
    You are right, they do need to be replaced.
    I was just curious if the type of shingle has a bad reputation.
    The house had several different roofs and the owner gave me ages for all of them which I could believe given their condition. This one section of roof threw me.
    Thanks again...
    Jon
