Thread: Electric panel
    Manuel Noval's Avatar
    Manuel Noval Guest
    Default Electric panel
    Should a home inspector take the electric panel cover off, during the 4 point home inspection?
    Default Re: Electric panel
    Quote Originally Posted by Manuel Noval View Post
    I would if I was doing one, how else could you see the condition of it?
    If it was an FPE or a Zinsco panel I would not take the cover off of it.
    Manuel Noval Guest
    Thanks for the tip!
    mathew stouffer's Avatar
    mathew stouffer Guest
    If you are paying him/her more than 50 dollars
    Thanks for the tip!
    Manuel,
    There is a good reason Scott said he would not take the cover off an FPE or Zinsco panel - either one would be written up for replacement anyway, so why take the cover off and risk the things which might happen with those two (unlike other brands of panels).
