Thread: Things in panel
07-18-2011, 02:26 PM #1
Things in panel
I used to konw what these were but not this minute, so what are the blue things at the bottom of the panel?
07-18-2011, 03:55 PM #2
Re: Things in panel
Those are CTs (Current Transformers) and they have been removed.
When a conductor is placed through the opening in the CT, as current flows in the conductor it produces a magnetic field, which produces current in the CT, and voltage at the CT leads. These can be used for various uses, including monitoring the power being used, the amount of current flowing, and for tripping overcurrent devices, among other uses.
07-18-2011, 04:01 PM #3
Re: Things in panel
They look like current transformers that are not currently being used since there is no wire going through the hole in the middle..
07-18-2011, 04:05 PM #4
Re: Things in panel
Thanks guys, a heat pump was removed from the house, could these have been used for the control system of the heat pump?
David Smith
07-18-2011, 04:17 PM #5
Re: Things in panel
In a residential application they are normally used for monitoring and not control. But anything is possible so I would look for some more leftover parts....like a receiver of some type.
