Thread: heat controller
    Default heat controller
    heat controller a/c unit ser # 00B-C10491 mod # RSA1042-1Z
    any age ideas, company closed today
    Thanks Wayne
    Jun 2011
    Mississippi
    Default Re: heat controller
    Wnat brand did you say this was?
    heat controller
    Brian Markel's Avatar
    Brian Markel Guest
    Smile Re: heat controller
    heat controller
    Looking at SN - might be 2000. Same as Aitions' - upto 1976 coded to 1st four digits. EG: serial x506 = 1975 and 06 = June
    From 1976 to approx 1990 coded to 1st five digits. EG: serial x 7809... = 1978 and 09 = Sept
    Newer numbers, 1st two numbers for Year. EG: serial 95B-CP2810 = 1995
    Hope this helps
    My guess is April, 1991. Does it look that old?
    Thanks Brian
