    wood7926's Avatar
    wood7926 Guest
    Default on central A/C ductwork ,
    on central A/C ductwork , is the end of the trunk line suppose to be block off
    and the vents run from the sides of the main line?!!!!!!!!!!!!!!!
    Mark
    Default Re: on central A/C ductwork ,
    Quote Originally Posted by wood7926 View Post
    Mark
    In most designs, yes, that allows the air handler unit to create a static pressure in the duct.
    With the end of the duct open (at a supply register), most of the air will simply go through the duct and out that supply register.
    wood7926's Avatar
    wood7926 Guest
    Thanks Jerry,
    If you don't have a cap to block it off, what can you use instead?
    Mark
    Mark,
    Your response makes me ask: Do you mean the end is open and goes nowhere?
    I was expecting the end to go to a supply register, in which case just closing the supply register would 'help' - but not 'solve' the problem.
    The answer to your next question as to what to use depends on the type of ductwork you have: a) fiberglass ductboard; b) square or rectangular metal; c) round metal; d) flexible duct; those are the main types of duct used in houses and their use depends on location in the country and the age of the house.
