    Aug 2009
    Raleigh
    Default bulb on ceiling close to sheet rock
    Noted this in a convoluted home. Light fixture in center of room and they enclosed HVAC ducts in sheet rock. Bulb is just a few inches from sheet rock. My searching has not provided anything that might prohibit this. Any ideas?
    Chico,Ca
    Default Re: bulb on ceiling close to sheet rock
    Unless it had a extremely large lamp installed (such as a 300W) & don't see that in the pic, I don't see any issues.
    Jul 2011
    Central PA
    Quote Originally Posted by Randall Clark View Post
    I would recommend a globe cover but other than that, I think it's OK.
    Tolland, CT
    Quote Originally Posted by Matthew Steger View Post
    yes most codes do not allow exposed bulbs.
    On The Mason-Dixon Line
    Quote Originally Posted by Michael Derrick View Post
    This statement would be much better had you provided the code and section
    Atlanta, Georgia
    That is true for closets. NEC 410.2 (2008 edition)
    Can you provide an NEC or IRC reference that does not allow exposed bulbs in living space?
