Thread: CCAW
    Sep 2009
    Las Vegas, NV
    Default CCAW
    Does anyone have experience with or comments about Copper Clad Aluminum Wire used for residential whole house wiring?
    Default Re: CCAW
    What year is the house?
    Sep 2009
    Las Vegas, NV
    Default Re: CCAW
    A townhouse built in 1976, Las Vegas, NV
    Default Re: CCAW
    In my experience it has the same problems as any aluminum wiring that is used for branch circuit wiring. The wire is still soft and gets loose and can heat up at a connection or terminal.
    Default Re: CCAW
    Copper clad aluminum is treated the same as aluminum wiring, it must have devices rated for aluminum wire.
    Being as the wiring is the same, with the except of the copper cladding over the aluminum, it is susceptible to the same problems as aluminum wiring.
    Chico,Ca
    Default Re: CCAW
    CU clad AL is sized like aluminum but can be terminated like copper, there are many wiring devices that are marked "CU or CU clad wire only", there is no other reason to have CU clad AL.
    IMO, any aluminum conductors smaller then 6 AWG is a bad thing, but "low bid" rules the roost.
    Lou Romano's Avatar
    Lou Romano Guest
    Default Re: CCAW
    Tha is pretty much how I see it as well!
