Results 1 to 15 of 15
    Ron Bibler's Avatar
    Ron Bibler Guest
    Talking Electrical shock from the cover of this Zinsco panel
    I Removed the cover from this Zinsco panel today and dang what happened to the guy that did this
    Don't let this be you
    I did not re-install the cover... I tape the door off for Safety... The owner need to call Sparky. A.S.A.P.
    Best
    Ron Bibler
    Santa Rosa California Home Inspection - Exterminating & Thermal Imaging
    www.sonomehomeinspection.com
    Default Re: Electrical shock from the cover of this Zinsco panel
    I alway tape the top with several layers of tape before I put them back on.
    I recently finished my required NC training for electrical safety. I learned that those Zinsco panels were originally considered part of the service equipment and were not intended to have the inside cover removed without first removing the meter to disable the power. I don't remove meters and that panel needs replacing for other reasons.
    www.BAKingHomeInspections.com
    I'm fine Ron. Thanks for asking.
    Roger Frazee's Avatar
    Roger Frazee Guest
    Failure to follow the cover removal instructions attached on the inside surface of the panel cover ...
    Ron Bibler's Avatar
    Ron Bibler Guest
    I would bet this happened when the they were trying to put the cover back on. Not from trying to remove it...
    At any point these panels can bite big time. look at this other arc flash point in the panel. at first i was thinking some one was doing some repairs. But after thinking about it this was part of the original arc flash.
    OUCH!
    Best
    Ron
    Reason #2 for not removing the cover of a Zinsco panel!
    Feb 2010
    Long Beach, CA
    Here's a nearly burned-through meter bar on a Pushmatic...
    Ron Bibler's Avatar
    Ron Bibler Guest
    Quote Originally Posted by Marc Morin View Post
    Marc... Do you have some more photos of that panel.
    Best
    Ron
    May 2010
    No. San Diego Co., CA
    While on the subject of panels and dead-fronts...Here's an interesting 'find' from recent inspection.
    The deadfront was replaced with a sheet of plastic, with cut-outs to accommodate the breakers. The plastic was then trimmed with 1/4 round and completely hot-glued in place, including gluing some of the breakers...I guess they were a bit loose!. The innovator had the presence of mind to make it 'look nice' by spraying it matte black.
    No, I did not even attempt to remove it.
    I suppose its better than NO dead front.
    877-466-8504
    Ron Bibler's Avatar
    Ron Bibler Guest
    Quote Originally Posted by Dana Bostick View Post
    Kinda make you think ? What became of the original cover?
    Did he use it to make something else. Like a cover for his tractor with a bit of duct tape
    Best
    Ron
    Feb 2010
    Long Beach, CA
    Ron,
    Here you go...
    Feb 2010
    Long Beach, CA
    Ron,
    A few more...
    Binford Tools's Avatar
    Binford Tools Guest
    Good ole Zinsco. Where you inspecting how tight the lugs were on the breakers, or some pink or blue or other color wiring?
    I just push each breaker slowly to the off position noting how far one has to push it. If you get to the off position and the breaker has not tripped, that's a problem. A new one trips at 1/3 of the way to off. So if they go much past the half way mark the breaker spring is toast.
