Thread: Cricket
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cricket
    Does this chimney require a saddle or cricket if its angled. Home built in 06
    Default Re: Cricket
    Well it sure looks like more than 30 inches wide, but it its also both a chimney and a cricket combined.
    Default Re: Cricket
    2006 IRC: R1003.20 Chimney crickets. Chimneys shall be provided with crickets when the dimension parallel to the ridgeline is greater than 30 inches (762 mm) and does not intersect the ridgeline. The intersection of the cricket and the chimney shall be flashed and counterflashed in the same manner as normal roof-chimney intersections. Crickets shall be constructed in compliance with Figure R1003.20 and Table R1003.20.
    Default Re: Cricket
    Thanks, I missed that key work.
    Default Re: Cricket
    The wording changed for the 2009 IRC, R903.2.2 in the event your area uses it.
    A cricket or saddle shall be installed on the ridge side of any chimney or penetration more than 30 inches (763mm) wide as measured perpendicular to the slope. Cricket or saddle coverings shall be sheet metal or of the same material as the roof covering.
