Results 1 to 4 of 4
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Weil Mcclain boilers
    Do these boiles have AL heat exchanges. The boilers are about 17 years old. Also anyone have a general idea of the life expectancy. Typically 20 to 25 is what I have found. These guys get worked pretty hard, they are around 8700 feet.
    Zibby Bujno's Avatar
    Zibby Bujno Guest
    Default Re: Weil Mcclain boilers
    where is that water coming from? leak?
    this handy site will give you exact age.
    CP Lookup
    the wonder of internet
    Residential Gas-fired Boiler | GV Gas Boiler | Weil-McLain
    gas cast iron sectioned boiler will go 25-30 years
    unless they are leaking like that one
    Zibby Bujno Guest
    check your condensate drain path (overflow, plugged etc.)
