    Sep 2008
    so so, California
    Default Another hot Zinsco
    I smelled this one before I even opened the panel, hmmm burning plastic.
    Default Re: Another hot Zinsco
    The Zinsco panels that are part of the meter panel are designed to only be opened after the meter has been removed since no protection is present to keep the cover from tilting into the main lugs. Whoever designed these is an idiot. Then, of course, you have the regular zinsco issue that requires replacement anyway so removing the cover is not even needed.
    www.BAKingHomeInspections.com
    Mount Pleasant, SC
    Wink Re: Another hot Zinsco
    "hot" would also be a little easier to ascertain if you showed spot temps in your IR pics...
    Jus saying!
    www.atozinspector.com
    Sep 2008
    so so, California
    Quote Originally Posted by Mike Gault View Post
    Jus saying!
    I dont show temps on my images. But if you must know, it was over 200+ degrees above ambient...just sayn
    Darrel Hood's Avatar
    Darrel Hood Guest
    Its my dumb question time. How is a panel inspected using an IR camera? I can understand how a circuit with an operating load is inspected. However I don't understand the examination of a circuit that is not in use. This seems to make examination of a panel largely dependent on luck, ie only valuable for circuits in use.
    Thanks in advance.
    Sep 2008
    so so, California
    Thanks in advance.
    Well, with residential, I load the panel with whatever is avialable to me which isnt typically more than lights. But..if the panel performs in a manner such as this, under minimal or no load imagine what happens under heavy load.
    With Zinsco I dont rely on temps for my evaluation. If I find any heat within the panel I write it up. I have 3 panel boards in my garage that I scanned and were later replaced, all had damaged busses and, ALL were less than 100 degrees of ambient.
    Sep 2008
    so so, California
    Nother.... The only load was the microwave, range LCD and a 40Watt bulb.
    Aug 2010
    BC Canada
    Hi, Marc
    Was the Microwave on at the moment you were inspecting the panel? Did you turn it on for 15 mins then went to open the panel?
    I am curious how the breakers get the temp without load.
    Garland, TX
    Hi, Marc
    Peter,
    look closely at the 10/1/2011 image
    it's doubtful those appliances & general lighting are on those 220/240 V ocd, ymmv
    hny
    Sep 2008
    so so, California
    Hi, Marc
    Dont remember but doubt it.
