    Don Martin's Avatar
    Don Martin Guest
    Default Service Connection
    This was next door to my inspection and it caught my eye
    Default Re: Service Connection
    Try again
    Try again
    I was napping in my truck and ......
    Don,
    Call Your locale Utility Company and have them Straighten that Service Drop Out.
    * Most Likely illegal Hookup as evident by Wire Ties and Tape.
    Don Martin's Avatar
    Don Martin Guest
    Smile Re: Service Connection
    The wire nuts and tape just didn't look right at a distance. At least he left the utility barrel connectors in place so he could wire nut copper to copper:-)
    Here is another one I came across about 3 years ago.
    Quote Originally Posted by Don Martin View Post
    Now that looks like a 3- wire feed to a garage or outbuilding. The correct clamp is missing.
    The neutral should be insulated, but I'm not sure if it is a requirement?
    Don Martin's Avatar
    Don Martin Guest
    PO put an un-permitted addition on the back of the house. He installed the new service on the back of the addition (20 feet closer to the utility pole) and since he had some extra wire fed the live service wires into the panel. No splices of the conductors at the weather head.
    Around here all the utility splices are barrel connectors. Some of the older connections may be split bolts.
    Oct 2009
    michigan
    Looks like a galvy plumbing roof flange... as opposed to a listed elect roof riser plate. I'm getting tired of writing this one up. ugg
    Sep 2009
    Dallas, TX
    Ha, ha!...I don't think that's a "Neutral". I think that's a "Roof Anchor". He spliced a neutral into a support cable! Well, at least he found someting to connect it to. "Huuuumm,,,,two hots soooo...THIS one must be the neutral". Bad news for squirrels around that house.
    Quote Originally Posted by Robert Slight View Post
    Except for the unconventional connection to the insulator, this is no different than any other triplex aerial drop from the power company. In the neutral is a steel wire that supports the triplex.
