    Southwest US
    Default PVC cold supply piping
    Inspecting a mid 1980's house tomorrow that has white PVC cor the cold piping, CPVC for the hot. Is this not allowed, was it always not allowed? Besides DIY issues, what are the potential problems (breakage, etc.), should the house be re-plumbed if there are no apparent problems?
    As always, Thanks.
    Nov 2007
    Chicago
    Default Re: PVC cold supply piping
    Here in Illinois we are allowed to use PVC on cold water supply only. But most counties, towns, and cities will not allow it. Best to check with you local plumbing inspector to see if it is allowed in that town.
    Jeffrey L. Mathis's Avatar
    Jeffrey L. Mathis Guest
    If you're state licensure board is like North Carolina, don't say it was against code unless you can site code chapter and verse.
    JLMathis
    Nov 2007
    Chicago
    Quote Originally Posted by Jeffrey L. Mathis View Post
    JLMathis
    Hope this helps:
    TITLE 77: PUBLIC HEALTH
    CHAPTER I: DEPARTMENT OF PUBLIC HEALTH
    SUBCHAPTER r: WATER AND SEWAGE
    PART 890 ILLINOIS PLUMBING CODE
    SECTION 890.APPENDIX A PLUMBING MATERIALS, EQUIPMENT, USE RESTRICTIONS AND APPLICABLE STANDARDS
    Section 890.APPENDIX A Plumbing Materials, Equipment, Use Restrictions and Applicable Standards
    Section 890.TABLE A Approved Materials and Standards
    All materials must meet at least one of the approved standards listed.
    Approved Materials for Water Service Pipe
    1)
    Acrylonitrite Butadiene Styrene (ABS) Pipe2
    ASTM D 1527-1996a
    ASTM D 2282-1996a
    Joints
    ASTM D 2235-1996a
    Solvent Cement1
    ASTM D 2235-1996a
    2)
    Brass Pipe2
    ASTM B 43-1998
    3)
    Cast Iron (ductile iron)2
    ASTM A 377-1984
    Water Pipe
    CSA B70-1997
    4)
    Chlorinated Polyvinyl Chloride (CPVC) Pipe2
    ASTM D 2846-1997M
    ASTM F 441-1997
    ASTM F 442-1997
    CSA B137.6-1999 in B137
    Joints
    ASTM D 2846-1997M
    Solvent Cement (Orange)1
    ASTM F 493-1997
    5)
    Copper/Copper Alloy Pipe2, 3
    ASTM B 42-1996
    ASTM B 302-1998
    6)
    Copper/Copper Alloy Tubing2,3
    ASTM B 88-1996
    7)
    Galvanized Steel Pipe2
    ASTM A 53-1998
    ASTM A 120-1984
    8)
    Poly Butylene (PB) Pipe/Tubing2
    ASTM D 2662-1996a
    ASTM D 2666-1996a
    ASTM D 3309-1997a
    CSA B137.7-1999 in B137
    CSA B137.8-1999 in B137
    9)
    Polyethylene (PE) Pipe2
    ASTM D 2239-1996a
    10)
    Polyethylene (PE) Tubing2
    ASTM D 2737-1996a
    CSA B137.1-1999 in B137
    11)
    Polyvinyl Chloride (PVC) Pipe2
    ASTM D 1785-1996b
    ASTM D 2241-1996b
    ASTM D 2672-1996a
    CSA B137.3-1999 in B137
    Joints
    ASTM D 2855-1996
    CSA B137.2-1999 in B137
    Primer
    ASTM F 656-1996a
    Solvent Cement1
    ASTM D 2564-1996a
    12)
    Welded Copper Water Tube2
    ASTM B 447 WK, WL, and WM-1997
    13)
    Solder
    ASTM B 32-1996
    Agency Note:
    1Solvent cement must be handled in accordance with ASTM F 402-1988.
    2Water service pipe must meet the appropriate NSF standard for potable water.
    3Type K or L copper may be installed underground.
    Approved Materials for Water Distribution Pipe
    1)
    Brass Pipe2
    ASTM B 43-1998
    2)
    Chlorinated Polyvinyl Chloride2 (CPVC) Pipe/Tubing
    ASTM D 2846-1997
    ASTM F 441-19973
    ASTM F 442-19973
    Joints
    ASTM D 2846-1997M
    ASTM F 493-1997
    3)
    ASTM B 42-1996
    ASTM B 302-1998
    4)
    ASTM B 88-1996
    5)
    Cross Linked Polyethylene2
    ASTM F 876-2000
    ASTM F 877-2000
    CSA B137.5-1999 in B137
    6)
    ASTM A 53-1998
    ASTM A 120-1984
    7)
    ASTM D 3309-1997a
    8)
    Polyvinyl Chloride (PVC) Pipe2, 3
    ASTM D 1785-1996b
    ASTM D 2241-1996b
    ASTM D 2672-1996a
    Joints
    ASTM D 2855-1996
    Primer
    ASTM F 656-1996a
    Solvent Cement1
    ASTM D 2564-1996a
    9)
    10)
    Solder
    ASTM B 32-1996
    Agency Notes:
    2Water distribution pipe must meet the appropriate NSF standard for potable water.
    3Use for cold or tempered water only
    As for what Cities, townships, and counties they are allowed to make the code stricter but nothing less than the the Illinois Plumbing code.
    As always, Thanks.
    Out of curiosity, did you attempt to contact the local building permits office?
    Oct 2007
    Southeastern Virginia
    I was just curious, Ron has supplied an abundance of material from the Illinois Dept. of Public Health.
    Does the Illinois Dept. of Public Health administer, interpret and enforce the building codes in Illinois?
    Jamie R Wilks
    Virginia Certified Home Inspector
    Southwest US
    Not applicable, the City was under the County building department at that time and there were basically no rules enforced. Build whatever you want!!
    Nov 2007
    Chicago
    I hear home owners say that all the time to me, and I hate to say it they are full of BS. If you are building in Incorporated areas where the county is in charge, they have county building , pluming and other inspectors. And if the county does not have any I can tell you the state does.
    All states have or follow a plumbing code and the homes need to be built to code.
    The key is where you say "... there were basically no rules enforced ..." being enforced or not being enforced does not mean that rules did not exist. Enforcement is a different subject. Rules at time of construction is the question and the answer.
    The use of PVC and CPC in practice revolves around the use of chlorination in the water, the temp that the material will be subjected to and the pressure the material will be subject to. When the use of CPC for all supply lines was required just mane it easy easier to inspect and upgraded the cold lines to a higher specification (no harm no foul). The big basic issue is about expansion of the pipe and joints under heat.
