    Daniel Island, SC.
    Default Gas line to new metal fireplace
    Galvanized gas line stubbed out in metal fireplace with ceramic liner. Exterior cut off on wall. Damper. Stubbed out metal gas line has a nut on the end. New house!
    Question:
    Can this fireplace be used as a wood burning fireplace since the gas logs are not installed?
    Jim
    Default Re: Gas line to new metal fireplace
    The short answer is, "If it's approved for wood fires" by the manf.
    Most pre-fab fireplaces are approved for both wood and gas logs - but not all.
    By the way, I hope there is a cap or plug on the gas line and not a nut.
    Daniel Island, SC.
    Thanks Jack,
    Yes, it had a plug or cap on the end!
    Jim
