Thread: Another painted panel
09-30-2011, 06:30 PM #1
Someone confiscate that guy's spray equipment!
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
10-01-2011, 04:40 AM #2
Re: Another painted panel
Makes you wonder what other quality contractors the builder used.
10-01-2011, 06:57 AM #3
10-01-2011, 11:11 AM #4
I'm sorry, but this is not the fault of the painter. The electrician failed to properly cover his equipment prior to the painting.
The electrician has to know better!
10-01-2011, 07:06 PM #5
That was going to be my first response to ... then I remembered having seen many properly covered panels with their covers ripped off and laying on the floor because someone took them off *after* the electrician left.
Yes, but welding on metal covers is a bit beyond what should be needed, beside, that may void the listing of the panel anyway.The electrician has to know better!
10-03-2011, 09:37 AM #6
