    Mar 2009
    Charlottesville, Va.
    Default Is this a Smoke or Carbon Monoxide Detector
    I need help indentifying the device in the attached picture. I assume it is either a smoke or carbon detector but could't tell. The house was built in 1974 and there was only one other detector (obviously a smoke)installed in the hallway along with this one. Other than "do not paint" there were no markings I could see on this one. I tried to twist the cover off with light pressure, but no going. There was a propane fired log set installed in the living room. The house had no security system installed.
    Thanks.
    Oct 2011
    Eastern Shore of MD, NEC 2008
    Default Re: Is this a Smoke or Carbon Monoxide Detector
    It is a UFO.
    Go back, make sure it is de-energized in case it is line voltage(120v), and get the darn thing down. Try putting slight upward pressure on the device as you twist.
    Quote Originally Posted by Robert Foster View Post
    Thanks.
    I do not recognize it so I can't say for sure.
    All smoke and CO detectors that I am familiar with have an LED indicator.
    I do not see that on this one.
    Heat detectors do not have LED indicators.
    So I think it's a heat detector.
    New York
    Thanks.
    It resembles a heat detector. But, I have never seem one with a white cap. The ones I am used to seeing have a silver "button" similar to gold/white one in your photo.
    Is is much smaller than the average sized somke/co detector?.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Wow. Great catch!
    Mar 2009
    Thank you for all the replies ...
    Rick ... I owe you one for making go from not knowing anything to looking like a genius.
    The article says it may be a heat detector, then it shows a pic of the UFO agin. I don't get it. Did it fly from there?
    Glad I could help
