    Doug Mills's Avatar
    Doug Mills Guest
    Default Fire wall between living space and barn
    Hi,
    I'm looking at a house which needs renovating and am wondering if a barn is the same as a garage? Here in Maine we are required to use 5/8 fire rated sheetrock between living space and garage. Is this the same for a barn? Do I need a steel fire door or can a solid wood door be used?
    Thanks,
    Doug
    Nov 2009
    St Paul, MN
    Default Re: Fire wall between living space and barn
    If the barn is attached to the house the answer is "Yes", treat it the same way as an attached garage.
    Check with your local code officials regarding the fire rating of the door. Most require a minimum of a 20 minute door. It could be steel or wood as long as the rating is met.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Do you really want a door to connect the barn to the house? OK if you are converting the barn to a workshop, treat it like a garage. If you plan to house livestock in there, seal that space off from your living space.
