Thread: Fire Grenades
    Feb 2010
    Wenatchee Wa
    Default Fire Grenades
    Thought I would share this with you all.
    The chemical in the grenade, carbon tetrachloride, was appropriate for both liquid and electrical fires. It was a common chemical used in extinguishers from the early 20th century to about the 1950’s.
    There was one small issue though. The chemical carbon tetrachloride is toxic and acute exposures cause damage to the nervous system and internal organs.
    Another issue is that when CTC is exposed to heat it forms phosgene gas, more commonly known as “Nerve Gas”.
    So if you ever get lucky to run into one of these bad boys you can let your clients know.
    Don Hester
    NCW Home Inspections, LLC
    Default Re: Fire Grenades
    Thanks Don for the latest Post on these Contraptions.
    fire grenades - Home Inspection & Home Inspector Services For Inspections and Inspectors
    Jeff Spencer's Avatar
    Jeff Spencer Guest
    Thanks for the article.
    I've run into them twice. The first time, the fine folks here educated me.
    Jeff
    David Adams's Avatar
    David Adams Guest
    I saw these on Auction Hunters. The shows hosts found some in a storage unit they won at auction. They tried one out on a fire and it seemed quite effective at putting the fire out.
    Feb 2010
    Wenatchee Wa
    Billy,
    Thanks for the other link, good stuff.
    These can be collectible, but the CTC is nothing to mess with.
    Some fire depts may want them also for their displays.
    Don Hester
    Dr. Oliver Sachs wrote a story about an experience he had with a patient who was exposed to carbon tet in his book, "The Man Who Mistook His Wife for a Hat". Great story, great book, great guy.
    Dan Cullen
    www.domicileconsulting.com
