Results 1 to 14 of 14
Thread: Height of main disconnect
10-23-2011, 05:20 AM #1
As you can see in the photo, the height of the main disconnect is just above the top of this door. (cover removed by me).
Is there any max or min height requirement for access?
10-23-2011, 06:33 AM #2
Re: Height of main disconnect
From the 2011 NEC
404.8 Accessibility and Grouping
(A) Location. All switches and circuit breakers used as switches shall be located so that they may be operated from a readily accessible place. They shall be installed such that the center of the grip of the operating handle of the switch or circuit breaker, when in its highest position, is not more than 2.0 m (6 ft 7 in.) above the floor or working platform.
10-23-2011, 07:10 AM #3
The power company may have stricter rules regarding the acceptable mounting heights. Typical is 4' to 5'6 to the center of the meter.
10-23-2011, 07:31 AM #4
beach house right?
did you call the local Building dept?
10-23-2011, 08:32 AM #5
It is a beach house, constructed in the 60's, major renovations (with permits) in the late 80's.
It's been there for a while, so I guess if the electric company had any beefs, they would have stepped up by now.
My curiousity got me as I had a hard time trying to reach the panel to determine the breaker size.
10-23-2011, 08:35 AM #6
Just curious ... how close was the siding, and the wall framing behind it, to the ground/stone?
10-23-2011, 09:39 AM #7
10-23-2011, 10:18 AM #8
10-23-2011, 10:30 AM #9
Great observations and questions!
The lower level of the house is block foundation. The siding is cladding over the block. (plywood and shingles) for cosmetics.
10-23-2011, 02:28 PM #10
10-23-2011, 06:44 PM #11
Ken - I'm telling ya, I must have inspected the house right next door to the one you inspected ? Except when I got there, the power panel was quite lower, it was high tide (as you can see by the water) and a cute blonde was standing at the door way. For a short while I lost focus on what I was doing there ? Then I realize .. "Oh yea, a home inspection"
10-24-2011, 04:24 AM #12
Robert,
Neat trick. You had me fooled for a while. (And she is definitely a cute one)
What software did you use to doctor the photo?
10-24-2011, 04:45 AM #13
10-28-2011, 08:42 PM #14
Ken - Thanks. It's called Corel Paintshop Pro X4. One of my hobby's is photoshop. I saw your pic and knew right away I could manipulate it with some good affects. I agree, the girl is a cutie.
I had to find one that looked as though she's standing up against a pole. The water and power panel was a cut, paste and erase task. It does make you look at the two pics for awhile and say ... "Hey this is the same pic" - lol
Rick - I don't know exactly what you mean by ... "The Professional Inspector", it's available for free at NACHI.
