Results 1 to 2 of 2
    Default Condo's and Radon testing...
    Had an odd one...
    A 1st floor condo on slab buyer wanting a Radon Inspection.
    Makes perfect sense...
    However, I warned them that if the numbers came back high, the seller might not be able to remediate the Radon as they don't own the foundation/slab/structure and it would be up to the Condo association to do that, and they might not want to open that can of worms....
    How would you have explained/written the possible limitations of Radon in a Condo?
    South-West Michigan
    Post Re: Condo's and Radon testing...
    I would perform the test and report the result. If there is a concern, it would likely be a concern for the entire building. It would be up to the seller to take up with the association. The lawyers can sort out who would be responsible for remediation costs.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
