04-03-2007, 06:18 PM #1
Brick Veneer Exterior Wall 90 deg inside joint
Envision two exterior walls coming together with an inside corner (at an entrance door). Every home I have inspected has either mortar or a flexible sealant at the joint. A new home I am inspecting in the county has neither. Builder says show me where I have to have a seal. I have never inspected a home without one. I thought it was common sense. Can anyone provide the applicable code reference?
I gave a cursory look at the Brick Industry Association site, but didnt have time to go through the whole thing. First time I have every came across something like this.....
Thanks for any help you can offer. You will save me some time and trouble for sure.
04-04-2007, 08:33 AM #2
Re: Brick Veneer Exterior Wall 90 deg inside joint
need a picture. are the bricks butting up against each other at the corner with no mortar.? dry connection?
04-05-2007, 06:52 PM #3
