    Sep 2009
    West Dundee, Illinois
    Default Multiple PVC Flues Ganged together
    I am working on designing a large house. The house will have 2 water heaters and 4 furnaces. All will be high efficiency units. My question is: Is it possible to gang the PVC flues together and gang the PVC intakes together?
    New Mexico
    Default Re: Multiple PVC Flues Ganged together
    That's going to be a question for the manufacturer's. I doubt that they will be in favor of it. In theory yes, it could be done. In reality, I'm not sure you'll find an approved setup. PVC isn't that expensive. I see the problem more on the exhaust side than on the intake.
    Sep 2009
    leonardo, new jersey
    Always check with the manufacturers web site or call, I have never seen that, I just did a job this past saturday where the unit called for 3" vent and the contractor installed a 2-1/2" and the unit would not run. You need to follow the vent schedule for sure, very sensitive units.
    Joseph Ehrhardt
    New Mexico
    Just asking, in IL why wouldn't you use a boiler and baseboard or in floor radiant for the heat system? Is it for the AC system as well? I'm just not a big fan of forced air heat, but we don't need central AC here, which does change things.
    Sep 2009
    We get good cold and hot temperatures in this area. I've seen -25F and +103F. It's hard to heat smaller rooms with just radiant floors and we do need AC.
