Results 1 to 2 of 2
Thread: Foundation bolts
11-07-2011, 08:47 PM #1
Foundation bolts
Okay I have been looking for some thoughts on these bolts. They have chiseled the sill plate to get the bolt and washer on. This is in western Washington so we have some seismic considerations
I know that they are not installed with proper height but would like some of your thoughts on this particular installation.
Similar Threads:Last edited by Don Hester; 11-07-2011 at 08:57 PM. Reason: did not attach files
Don Hester
NCW Home Inspections, LLC
11-07-2011, 09:53 PM #2
Re: Foundation bolts
Well Don, I'm not an engineer, but I play one on TV
In general, most earthquake movement is lateral, not vertical. As a result, the chiseled mudsill is less of a problem than a notched mudsill. However, if there are more than one or two, it would add up and become a problem. In addition, the type of nuts indicate an older home. Older homes can benefit from additional seismic retrofitting.
All of that would be off the record, because I am not an engineer and not qualified to supply a professional opinion. On the record, I would note the condition and defer to an engineer.
