Results 1 to 17 of 17
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Furnace in the garage
    This is a first I wonder if they just forgot and stuck these in at the end.
    Default Re: Furnace in the garage
    I find them in garages all the time, just need to add some impact protection.
    Same here, it's a regional or climate thing. Most FAU/AHU & WH are both in the garage. Easier to service and replace too.
    Stephen G's Avatar
    Stephen G Guest
    Gets cold in Utah? that right wall is an outside wall? no insulation. Maybe not the best arraingement. I agree with having some dont hit me posts installed. This is common?
    Osceola, AR
    I have a couple of towns in the area that I service where this type install is fairly common.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Atlanta, Georgia
    Quote Originally Posted by Stephen G View Post
    Granted we only get 1-3 inches of snow once every third year, but the furnace is in the garage. It will heat the garage enough so that nothing freezes. Common setup in my area. Add a few bollards and good to go.
    Fairly common setup in my area of operation for homes built in the 70's and 80's. Currently builders just jam the appliances in the crawlspaces and attics. Temperature wise not a big difference. At least the garage does not have to contend with basically outdoor environment of a crawlspace.
    Approximately 80% of houses around here (Oregon) have furances in the garage. The regional differences are interesting.
    Stephen G's Avatar
    Stephen G Guest
    I dont know how well that would work here. Minus 25c in an un-insulated, unheated sorta garage.
    Regional differences is right.
    Feb 2010
    Wenatchee Wa
    Fairly common here in Washington, except in my area there is almost no gas appliances.
    Don Hester
    NCW Home Inspections, LLC
    Pretty common here in California as well. I did note that the vent connection of the water heater vent to the FAU vent is not proper. Supposed to be a Y branch fitting, not a Tee.
    877-466-8504
    Kalamazoo, MI
    I guess I would also recommend that the plenum be insulated (might be on the inside though???) since the unit is in the garage...same as if in attic or crawlspace (unconditioned). Your just wasteing heat otherwise.
    RJDalga
    http://homeanalysts.com
    Kalamazoo, MI
    New Mexico
    That's probably what keeps the pipes from freezing. The uninsulated plenum, that is.
    cuba_pete's Avatar
    cuba_pete Guest
    Seeing as how codes were written as minimums I would mention that installing a metal post (in addition to the raised platforms) would provide much more protection to these gas appliances. I know that most vehicles have bumpers higher than the 18 inches that most codes require for protection.
    I didn't even blink an eye at having the furnace in the garage...seems pretty common to me.
    The garage is not insulated for one and we get temps around -25 to -30. Also the furnace plenums are never sealed 100 percent so if you leave your car idling in the garage that can be a problem for CO. I think its a terrible idea But thats just me.
    Oct 2007
    Arizona
    I hope to see the furnace in the garage..most times they stick it up in the attic ..June-Sept is brutal!
    Succasunna NJ
    Has anyone considered through wall and membrane penetrations of a fire separation wall?
    Ducts (fire damper present?) electrical panel and plumbing box?
    Healdsburg, CA
    I see at least 4 write-ups in that photo.
    Jerry McCarthy
