    Jun 2010
    Greenfield Indiana
    Default Looking through an IR Port
    Just thought I would show the gang what it looks like to inspect high voltage connections through an IR window. I do this a lot these days.
    Default Re: Looking through an IR Port
    Quote Originally Posted by Art Tompkins View Post
    How can the spot temperature be 60 degrees and the reflective temperature be over 80? Please explain all the temperatures we see in the image so people have more of an understanding of how this stuff works. Thanks.
    www.dapkusinspections.com
    www.chicagoinfraredthermalimaging.com
    Infraspection Institute Certified Level III Thermographer # 8510
    Aug 2010
    BC Canada
    is 60+ F quite normal?
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    What are you calling "High" voltage and does that image tell you anything ?
