Results 1 to 12 of 12
Thread: Heat shield
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Heat shield
    Is this intended to be a permanent part of a heat shield or packing material. This is an American Standard 90 percent gas furnace.
    Default Re: Heat shield
    Aftermarket vibration dampener ?????
    Had a rattle/hum that bothered them.
    Appears that the shipping/packaging material was never removed.
    Apr 2008
    Western Massachusetts
    It's a noxious smoke generation system, for random testing of the smoke alarms in the home.
    David Bell's Avatar
    David Bell Guest
    They would take it out but it burned their fingers.
    Oct 2011
    Minneapolis, MN
    Thought it might be a good place to thaw out some steaks.
    - James Burgh, 1754.
    James Duffin's Avatar
    James Duffin Guest
    I agree with the rattle theory. No way that got there by accident.
    Rod Corwin's Avatar
    Rod Corwin Guest
    Also gets my vote!!
    Fuquay Varina, NC
    Had a similar situation on a 80 furnace in a mobile home. They used egg crate material. Only found 1 scorch mark on the three areas they stuffed it.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    May 2010
    St. George, UT
    I cant tell by the photo if it is a paper packing (egg crate) type material or if it might be a material that is similar to rock-wool insulation, like some of the covers being used over non-IC rated recessed lights. I'm just curious enough that I would break off a piece and and try to burn it. I would agree that it is probably been put there as a vibration dampener.
    Utah
    haha, some great replies. All related to The Darwin School of Fix It.
    ray jackson's Avatar
    ray jackson Guest
    I would say it was some packing material. Some older furnaces would have similar heat shields, but with this one being a 90% you just wouldn't have that much heat to worry about.
