    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Hot Tub Disconnect, jumper
    What is the purpose of this and is it acceptable.
    Default Re: Hot Tub Disconnect, jumper
    Do you have a close-up of the diagram on the panel door?
    No it would not come out clearly and it was tough to read
    It looks like a pump relay. Just call it a 'relay' if you don't know WTF it is and you didn't read the label. Or get us a better pic.
    It seems to be installed according to the instructions on the door by someone that had a clue.
    My Guess. Leviton 7590-XE SmartLockPRO Blank Face GFCI - Black OneStopBuy.com
    Roger Frazee's Avatar
    Roger Frazee Guest
    That's a conneticut electric spa panel using a contactor which is believed by some to prevent nuisance tripping of the gfci.
    The green jumper is just bonding the metal yoke of the gfci to the effective fault path
    Thanks. I didnt say anything about it
