Thread: Basement romex.
    Kevin McKinley's Avatar
    Kevin McKinley Guest
    Default Basement romex.
    In the basement, I have romex running thru the floor joist's from the breaker box. Can I run from a junction box above to an outside wall and down to an outlet. I plan on using romex clips secured to the concrete wall with anchors, to keep the romex tight to the wall. Will this instalation be okay?
    Default Re: Basement romex.
    Quote Originally Posted by Kevin McKinley View Post
    Nope.
    Are all the external wiring Rated for Outdoor use and protected from physical damage ?
    Nonmetallic sheathed cable needs to be protected from damage. If approved for your area, I would use MC cable rather than NM. Best bet, check with the local building department for clarification.
    Thanks for the reply. I'll just run down the wall w/ MC. Thanks again.
    Apr 2008
    Western Massachusetts
    Personally I'd use EMT or Wiremold raceways. If you're going to use AC/MC don't forget your bushings and make sure to get the right fittings for your transitions and boxes.
