    Ludwig Maxwell's Avatar
    Ludwig Maxwell Guest
    Default What type Moisture Meter is best for home inspector
    I am looking into updating one of my poorly working/old moisture meter to Extech MO290; Pinless Moisture Psychrometer + IR.
    Can any one provide some input, if this meter is good idea or is there some thing better out there plus where to buy and at what price?
    Thank you.
    Divinityinspectionservice.com
    Ludwig
    Default Re: What type Moisture Meter is best for home inspector
    Look into the GE Protimeter Surveymaster. It has a pin-less scanning mode as well as contact pins. Expect to pay $400-$450.
    New York
    Ditto
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Apr 2010
    Reisterstown, MD
    GE Protimeter Surveymaster is definately the one to get. After doing a bit of research I found one on E-bay. Works great, came with all the attachments and accessories.
    Still see them on E-bay from time to time. If you buy on E-bay make sure it comes with all the standard parts.
    Bob Kenney
    Independent Home Inspection
    Thank You for all your input.
    Ludwig
    Jul 2007
    Have 2 pin Extechs and they seem to go bad after light use.
    Will not buy that brand again.
    David McGuire's Avatar
    David McGuire Guest
    Mine too, didn't even get a year out of it and never dropped it.
    Jul 2007
    Quote Originally Posted by David McGuire View Post
    Yeah, they get to where you need a reset with the inside middle button then the LCD display goes blank.
