    Las Vegas, NV
    Default A new year! Drip Leg...Sort Of
    OK Johnnie, go on over and install the clients water heater and don't forget to put a drip leg in the gas line.
    Beacon Inspection Services
    Like Beacon On Facebook
    Jul 2009
    Lanham, MD
    Default Re: A new year! Drip Leg...Sort Of
    Quote Originally Posted by Bob Knauff View Post
    Wow! and even used a cast iron tee which, unlike malleable fittings are subject to breakage. Looks like homeowner handiwork!
    That's the beauty of cast iron fittings....you can remove them with a hammer!
    Las Vegas, NV
    It's actually black iron pipe which is acceptable to use for gas line. Cast iron cannot be threaded.
    Installer had the diagram oriented wrong and was dyslectic and was given a 90 and plug instead of a pipe and cap. What do you expect from a 12 yr old?
    Jul 2009
    Lanham, MD
    Nobody mentioned the black pipe which is acceptable. Cast iron fittings are NOT as they are easily broken by sudden shock. I've removed many steam/hot water heating systems piping by merely breaking the fittings with a hammer.
    Las Vegas, NV
    Quote Originally Posted by Steven Saville View Post
    Steven called the Tee cast iron in his response. You are correct though, cast iron can be easily broken.
    Me too...and watched the asbestos fill the air!
