    Mar 2010
    Prairie du Sac, Wisconsin
    Question Phone transformer? What's this?
    Has anyone seen these and what are they? The little black box is about 1 1/2" x 3" x 1/2" thick. The aluminum enclosure is about 2" x 4" x 10". I advised for them to be removed. 1950's vintage home. Thanks Joe
    Default Re: Phone transformer? What's this?
    Old telco demarc for POTS line. Why tell them to remove phone line equipment?
    Jul 2007
    You talk like a splicing tech.
    Spent a little time in Local 21 myself.
    Anacortes, Washington
    With the big ground cable does the demarc also function as a lightning arrestor?
    //Rick
    Anacortes, Wa. Home Inspections by Pacific Crest Inspections in Skagit, Snohomish, Whatcom and Island Counties, Washington.
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    Jul 2007
    Quote Originally Posted by Rick Bunzel View Post
    //Rick
    No ,they need to be grounded also.
    Around here, the old posts are used for terminals for attaching the new landlines. For some reason, the guys that install telephones in old houses really like those old transformer blocks.
    Jan 2011
    Mississauga, Canada
    It is just a old style terminal block used at at the demarc point. You see where drop wire (authority wire from the street) meets the interior wire (house wire).
    Surely not a transformer.
    Thanks,
    Mike.
    Mar 2010
    Thanks to you all. Glad that it is what I suspected. My reason for suggesting removal was because the cover was not secured and I thought there was potential for hot wires to arc against the aluminum cover. I'm relatively new and just haven't seen it all and I expect I never will. The client was not to concerned about using or having a landline anyways.
    Joe,
    Do you know how much voltage / amperage the line carries?
    Mar 2010
    No Gary I don't. Did not measure. I did read somewhere that it's about 48 VDC and probably low amperage.
    Dec 2009
    Florida
    Quote Originally Posted by Joe Borkowski View Post
    48 VDC and 90 VAC (Ringing Signal).
