Results 1 to 14 of 14
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Type of siiding?
    Single family home built in 1980. The siding was hard like stucco. I could not feel underneath for a weep screed or see any expansion joints becuase of the wood trim. There was about 4 coats of paint on the siding.
    Default Re: Type of siiding?
    Looks like the 4x8 sheets of stuff that used to be sold at big box stores. Wood composite sheet like T111 with the fake stucco coating on top. The top coating was somewhere close to 1/8" thick. Haven't seen that stuff in a long time.
    When I used to remove and replace it, the sheets were generally Ok. Edges under the 1x4 nail / detail strips were always rotted out. Probably the same scenario in your case. Those 1x's look fairly rotted and not caulked.
    I let the client know that it will be an ongoing maintenance item with possible full replacement at some point.
    Baton Rouge, La.
    Looks like Composition wall panels. Similar to Masonite products. They typically fail at the seams due to moisture penetration which cause the siding to swell and fall apart.
    James Bohac
    tabatha ness's Avatar
    tabatha ness Guest
    It looks like a Hardie panel, I enclosed a link. James Hardie Commercial: HardiePanel
    This is one of many brands.
    Quote Originally Posted by James Bohac View Post
    That's the way I see it.
    * it appears to be Installed Better than ( not saying much considering the delamination properties ) most with flashing and gap along the roof line.
    I can't imagine it's a Hardie panel installed in 1980... I've seen similar (and wondered what it really is) on that age of building before. I'm pretty sure there's even a thread or two on here of me asking.
    I'd lean towards a Masonite or straight plywood material with a skim coat. Plywood sheets were common for that time period. The thick trowel marks on the pictures are just like what I've seen before from the 70s/80s.
    Jan 2011
    Marietta, Georgia
    Looks like what I call Stucco Board. Not a real stucco product, just looks (sort of) like it.
    Compressed fiberboard/Masonite. Brown, crumbly fibrous material?
    Called stucoboard used very much in Calif not a bad product if kept painted
    Fuquay Varina, NC
    I'm surprised not to see allot of water damage in the first picture since there is no kick out flashing and there is a batten board next to it as well as a downspout adding to it above the roof.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Fuquay Varina, NC
    David are we suppose to decipher your intent
    Who's David?
    Who's David?
    Deleted Advertisement Account.
    It is Stucatto board siding. It was made by Masonite for many years.
