Results 1 to 32 of 32
    so so, California
    Default See what happened to me today..
    This, just from lifting up on the dead front...Pinched a conductor in the upper corner. Scared the crap out of me..
    Default Re: See what happened to me today..
    Yikes! What brand of breaker panel?
    Glad you are safe! Be careful out there.
    so so, California
    I cant remember the make of the panel. Stuff like this just keeps the possibility of some of the inherent dangers in your face, literally.
    On The Mason-Dixon Line
    123456
    so so, California
    Glad to hear you experienced no bodily harm. We all realize these things happen, but the question that jumped into my mind is.....
    Now that your actions violated the integrity of the conductor, what did you do to remedy the situation?
    AFA the issue, I just taped the bare wire and shut off the power with a note...
    I am going to guess was your exercise for the day ... ... jumping to that conclusion.
    We have all found pinched conductors in the panel, as such my guess would be that each of the previous lifts of that cover pinched that conductor, and the first pinch of that conductor "violated the integrity of the conductor", with the failure or the insulation progressing forward until Marc happened along to raise that cover one more time ...
    Now I've had my exercise for the day too.
    123456
    Easy there Buddy !
    First - HOW do YOU know this was NOT the first pinch ? Now who's
    jumping to conclusions ? ( So NOW you've had your excercise)
    Yep, that's why I said:
    Robert Meier's Avatar
    Robert Meier Guest
    This is one of the reasons why a few cheap cable ties should have been used when shaping in the panel. .
    James Duffin's Avatar
    James Duffin Guest
    That looks TW or THW wire. Did the house have a generator panel installed?
    Jul 2007
    Chicago
    Guessing you did not have the panel cover screw out and the fastener threads file cut into it.
    Glad you taped it.
    Glad you taped it.
    No, the sharp corner of the deadfront bit into the wire. There was no screw there. Scary design, that's why I asked the brand.
    The wire needs to be repaired by an electrician, so the tape would just be a temporary measure. Most of us know this without having to say it..
    so so, California
    No it didnt JD. And it was the corner which was pretty sharp that was the issue. I suppose It was one opening away from this happening anyhow. You should see the front of the screwdriver I was using.
    James Duffin Guest
    With all those red wires it looks like one of those generator panels Home Depot sales. The installation can really really fill up a panel.
    Lancaster, CA
    I'm guessing it was the hair that broke the camel's back..
    hard to imagine Marc, standing there, forcing panel open to point where it pinched wire... sounds like more of a progression or series of stuff.
    Oct 2011
    Minneapolis, MN
    To quote John, Yikes! This kind of thing makes me glad opening the panel is not one of my duties. Glad you're alright.
    With a long panel it wouldn't take much force lifting on one end to turn a sharp corner into an effective insulation cutter. It could easily have been the first time it got in the way. Is it common for them to be hinged at the top? Seems like a design flaw.
    - James Burgh, 1754.
    Robert Meier Guest
    Although it may not be the best design this one is on the installer. Certainly he should have known how the cover operates and shaped his conductors in accordingly. This one was caused by sloppy workmanship.
    Stuff like this is what makes a newbie like me utterly terrified. Electrical panels still scare me to death. Aside from the regular precautions (touching the panel with the back of the right hand; running the back of the hand up and down the breakers to check for hot ones, making sure you're wearing rubber soled shoes, etc.), what are some "veterans' pointers" for dealing with electrical panels when you're getting started as a home inspector?
    Welmoed Sisson
    Nov 2010
    Safety Harbor, FL
    I always take photos of the panel box with and without the deadfront on along with a pic of the manufacture's label and include the manufactures name in my report. I, like John would be interested in knowing who made this panel for future reference.
    Osceola, AR
    Quote Originally Posted by Welmoed Sisson View Post
    Ouch! Sorry but if you don't have much experience with electrical work you really should be more cautious while working with the equipment. Keep your hands out of the panels! Use a good non contact sensor on any metal equipment before you touch it. Panels, piping, HVAC equipment, metal siding, appliances and fences are just a few of the things I find during a home inspection that are energized. I carry a non-contact sensor in my shirt pocket and another in my tool pouch, and both get checked against a known source before use. I also carry a non contact thermometer for checking the temps of breakers
    I wear rubber soled shoes for inspections (check the soles for splits, nails, staples on a regular basis, not just for elec., this stuff scars wood and vinyl floors also), I wear all cotton clothing for inspections, with the exception of tyvek coveralls for attics and crawls. Safety glasses are a must for me along with gloves.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    so so, California
    Not to belittle Marc or anything,but to me it does sound like he was forcing it. I seem to remember he saying you should see the screwdriver I was using.
    you're not....I was pulling forward using the tab on the front. Put it this way, it barely moved and then...POP!
    Nov 2011
    Oregon, USA
    Amen, brother man!
    Oct 2009
    michigan
    Actually is was the lack of a dead front that led to this issue. The cover that was lifted up to open should not have the option to pinch a wire if a dead front was installed.
    Curious, was a dead front missing from this enclosure? Just what are we looking at, load center, disconnect, J-box?
    Lou Romano's Avatar
    Lou Romano Guest
    This is a GE panel or meter/main combination unit. I can see the breakers in the first picture and they look like GE wafers.
    state of jefferson
    i see many square d panels with this type of deadfront. it is called a deadfront because you could easily be dead when trying to remove the dam things. you pull out on the bottom to about 30 degrees then push the top in and pull the deadfront down and pull out. anything can happen and marc is lucky that a change of shorts was all he needed
    Robert Rolleston's Avatar
    Robert Rolleston Guest
    Yeah if you have to pry on a cover with a screw driver to remove it best to just leave it alone and have someone else check it out.
    Seconding the non-contact tester (I've wondered for years when someone does not come up with one you could wear as a ring, so it's always handy even with a tool in hand).
    Are you inspecting panels with your bare hands? Even a pair of the thin work gloves with leather fingertips and palms provide a significant dielectric.
    Someone will be along shortly explaining that we should all be wearing a full protective kit every time we open a panel - and on one level they are correct.
    But a decent set of gloves thin enough to allow enough dexterity to inspect a panel and a decent pair safety glasses provides a *lot* more protection than nothing at all when inspecting typical 240V residential panels.
    georgia
    The dead front is what appers to have pinched the wire it is shown in the first picture this appears to be a exterior enclosure with a top hinged cover then the dead front under that.
    Lesson learned if it takes a screwdriver to pry it up leave it alone and have it looked at by someone else.
    You are darn lucky that you did not get yourself a nasty shock.
    Rich Lewandowski's Avatar
    Rich Lewandowski Guest
    So who pays for the proper repair?
    Quote Originally Posted by Rich Lewandowski View Post
    IDK the original poster first said he was pulling up then said you should see what happened to the screwdriver I was using then he changed and said he was pulling forward.
    You can see the insulation is clearly peeled upwards and wire bent at almost a 90 towards the top of the panel.
    I know if was to accidentally break something and it required repair I would be more than happy to pay for it to get repaired. It's just something that makes me be able to get a good night sleep.
