Thread: Commercial Deadfront
01-16-2012, 05:11 PM #1
Do commercial property inspectors remove deadfront covers as do residential inspectors? A large building could have twenty or more panels, many at 460V.
01-16-2012, 06:59 PM #2
Re: Commercial Deadfront
It depends on the building and the client's expectations.
No, you would not normally remove all the deadfronts in a large complex. A business with 20 little old rental cabins, yes, open them all and make a list of all the screwups. If there is a suspicion of a problem in a panel, sure. If there is any concern with the larger service panels, it is normal to call for a professional to do further investigation.
This is something you should establish when you submit your estimate. You do a pre-inspection and decide what you will do for how much.
01-16-2012, 08:35 PM #3
Hello Garrett,
Panel covers of energized equipment should not be removed (especially 277/480 volt) with a few exceptions.
NFPA 70-E applies and appropriate PPE is required if the equipment is opened while energized.
ARC flash / ARC blast hazards are very real.
Stay safe.
Sincerely,
Corey
01-16-2012, 08:37 PM #4
deadfront; is it electric panel cover?
Is it dangous to remove a 600 V panel cover? otherwise, how can we find the fuse/breakers match, burn, 2 taps?
01-16-2012, 09:10 PM #5
Hi Peter,
The term "deadfront" is sometimes used to describe an electrical panel cover.
It is extremely dangerous to open (remove panel covers) 600 V panels. If you are inspecting facilities with 600 volt (or larger) equipment, a very qualified electrician is needed. A home inspector poking around those voltages has no business doing that and is putting himself and others at serious risk.
All inspectors should be familar with NFPA 70-E. It is also a good idea to take a class (you can do it on-line) pertaining to 70-E and arc flash training.
Sincerely,
Corey
01-16-2012, 09:37 PM #6
Thank you Coery
01-17-2012, 06:42 AM #7
If you are doing those types of buildings, there should be enough gravy in your inspection fee to bring a licensed sparky with you to evaluate such items. I've done it when I've had to but do not make it a practice. Larger stuff like that I just schedule my licensed sparky to come along and he looks at all the electrical while I do the building. Same goes for other technical items such as elevators, etc.
01-17-2012, 07:11 AM #8
Thanks, guys. Good advice.
07-25-2012, 11:26 PM #9
This property inspection is not an exhaustive inspection of the structure, systems, or components. The inspection may not reveal all deficiencies.
