Results 1 to 14 of 14
    Colorado Springs, CO
    Default Water Heater Vent Connection
    What say ye regarding this water heater vent connection?
    Bruce Breedlove
    www.avaloninspection.com
    Default Re: Water Heater Vent Connection
    It's ugly... the single wall part looks like it's too close to the wall and the transition before the ceiling almost looks homemade. I'd be curious to see what it does above the the ceiling.
    It's no prettier there, Matt. It has no clearance at all where it penetrates a wall and ceiling of the bathroom. (The waterstains around the waste pipe at the ceiling are another issue.)
    Bruce Breedlove
    Richard Stanley's Avatar
    Richard Stanley Guest
    Any combustion air??
    The water heater sits in a large laundry room. Combustion air is not an issue.
    Bruce Breedlove
    With a gas dryer?
    *HOW* "large"?
    Gas or electric dryer, both will depressurize a room.
    With a gas dryer?
    *HOW* "large"?
    Electric dryer. But point taken.
    If room depressurization from a dryer is a concern at the loose vent connection would it not also be a concern at the hood?
    Bruce Breedlove
    May 2007
    Frankfort, KY
    The difference is the draft hood is a designed hole where the other is a unintentional hole.
    There is a big difference.
    I really hope you don't take that statement seriously but I have been told that exact statement before.
    Yes it should be a concern Bruce as it can impact the appliances ability to vent.
    Open draft hoods make for nice make up air inlets using the vent pipe as the duct if the room is in a negative pressure scenario.
    Correct, however, gas adds in the additional combustion air needed to sustain combustion, and all that combustion air, in addition to the exhaust air, needs to be made up with make up air.
    Thus, gas is worse than electric.
    Exclamation simple arithmetic
    for every cubic foot of air leaving the room, an equal measure must replace it-period! Nature abhors imbalances. That's where we get this "path of least resistance" stuff. It will find a way. Now, we can control where or we can leave it to nature where we may not like her choice (backdraft) but it will happen one way or another.
    South-West Michigan
    Thumbs down Re: Water Heater Vent Connection
    The water heater venting is improper and unsafe. Repair or replace. Combustibles too close.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    That's pretty much what I reported. If the new water heater had been permitted the improper vent might have been avoided.
    Bruce Breedlove
    Huh?
    What world do you live in?
    The inspector would have probably just signed it off.
