    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Outlet along countertop
    This small table/countertop was anchored to the column which is boardering the kitchen. SFH built in 1992, I mentioned a missing outlet. Is this a toss up or would you categorize this as a countertop as well.
    Robert Meier's Avatar
    Robert Meier Guest
    Default Re: Outlet along countertop
    Good question. The fact that it's permanent makes it a countertop IMO.
    Bordering is your answer. Not in the kitchen. Obviously designed for a table and not a counter top.
    Jun 2010
    West Chester PA
    Agreed.
    I'd tell them if they want to put the toaster there, they should get a wireless.
    On The Mason-Dixon Line
    looks like a table to me , not a counter top.
    side note: would you consider that support column a wall or a column ? Looks like a column to me
    The NEC states that counter top receptacles shall be installed at each wall countertop space that is 12" or wider
    Healdsburg, CA
    A countertop NOT
    Jerry McCarthy
