    May 2010
    IL
    Default Gas pipe saddle valve
    Came across this today. 1st time ever. Is it allowed? My 1st response would be absolutly not. Your thoughts.
    This is tapped into a pipe feeding furnace. Tap goes to an outside grill.
    Nov 2007
    Chicago
    Default Re: Gas pipe saddle valve
    Illinos does not allow saddle fittings of any type for gas, water, or drainage.
    Those people are lucky there is still a house there to inspect. Unbelievable.
    Jul 2007
    Chicago
    I sure would not trust a saddle valve.
    That one looks older and not sure what type of gasket is involved.
    Certainly would have checked it for leaks.
    May 2010
    IL
    I did check it for leaks, and discussed replacing the pipe that has the saddle valve on it. Thanks for the input.
