Thread: moisture meter
    Odany Bravo's Avatar
    Odany Bravo Guest
    Default moisture meter
    Guys I'm in the market for a moisture meter. I'm looking at this 2 models just wanna see if what you guys think. thanks
    Tramex Survey Encounter & GE Protimeter Surveymaster
    Default Re: moisture meter
    Quote Originally Posted by Odany Bravo View Post
    I own and use both at almost every inspection. I use the SM around toilets, and on tile work. The Tramex for walls, floors, etc...
    If your budget can not afford both I would go with the SM at first and then when you can afford the Tramex you should get it as well.
    Odany Bravo Guest
    thanks guys
    I own both. I tend to favor the Tramex. Once in a while I pull out the Protimeter, usually to use the probes in an area where I can't place the Tramex.
