    Default reduced sanitary drain pipe
    Here's a good one - they reduced the 4" pvc so that it could be inserted into the old cast iron pipe just before it disappears under the floor. Nice try.
    Default Re: reduced sanitary drain pipe
    yeah! and i know you saw that oil line too
    Yep, but no longer in use.
