    Oklahoma City
    Default Chemical reaction?
    Home is only 5 yrs old and neither pipe has been replaced. Why would one be so tarnished and the other not at all?
    If it weren't for lawyers, we would never need them.
    Default Re: Chemical reaction?
    Poorly made flex connector, or no dielectric union/coupler on that piece.
    Oklahoma City
    There was a DE on that pipe. May not be working, but it was there. Still wondering what else it could be.
    Water heater is back-drafting, and sulfur is corroding the copper?
    The Guy who left his Foot Print on the Wall did it.
    Jul 2009
    Spokane, WA
    I'm with Dom. It definitely looks like sulfur corrosion. I would say Chinese drywall but it would likely be on both lines. Check for back drafting in the direction of the line.
    Apr 2008
    Western Massachusetts
    Flue gasses condensing on cold water line?
    Apr 2008
    Quote Originally Posted by Cishemant Mahajan View Post
    I heard that sodium reacts and catches fire in water, can you tell me the reaction and chemical formula.
    Na2 + H2O -> SpAm
    Oct 2011
    Minneapolis, MN
    Seems like an extreme example, but heat can speed up corrosion rates. Is the bad one the hot water?
    - James Burgh, 1754.
    Apr 2008
    Heat can speed up corrosion, but the type of corrosion present suggests something else. That's why I suspect it's the cold water pipe - if sulfur dioxide condenses on the cold water line with water it it will form sulfurous acid and sulfuric acid which will corrode copper as in the image.
