    Jul 2009
    Spokane, WA
    Default Plastic PEX fittings???
    Is anyone familiar with these plastic pex fittings. I've never seen them before. Any known problems?
    Jul 2009
    Spokane, WA
    Default Re: Plastic PEX fittings???
    House was built in 2002
    Nampa, Idaho
    That's WIRSBO brand PEX pipe and fittings. Good stuff, have in my own home. The plastic rings are expanded with a tool and slipped into place. The rings have a "memory" and shrink back to original size in just a few seconds. Just Google Wirsbo PEX for more info.
    Frank Luzar's Avatar
    Frank Luzar Guest
    Pex plumbing is good; however you might want to check the water pressure of the home; if its over 80 psi it can be harmful to the pex plumbing.
    Nov 2009
    Lynn, MA
    Wirsbo (now Uponor). Doesnt get any better than those fittings for reliability and quality. Best in the market.
    You can put the worst kink you can in that tubing, then heat it it up and it will go back to its original form and be no weaker.
    Timothy M. Barr's Avatar
    Timothy M. Barr Guest
    Been using them for about 4 years. good material Not cheap I pressure tested to 100 pounds hold for 8 hours
    Jul 2009
    Spokane, WA
    Thanks you all. The help is much appreciated.
    Oct 2008
    Portland, OR
    Quote Originally Posted by Mike Waldman View Post
    "The pipe of the future!"
    Utah
    Quote Originally Posted by Kyle Smith View Post
    I concur with others, this is good stuff.
